Problem installing zabbix/postgress - 'The frontend does not match Zabbix database.'
  • funkytwig
    • Jun 2016
    • 37
    Hi. I have a default postgress/zabbix/nginx install on Ubuntu 16.04. I am following the instructions at https://www.zabbix.com/documentation...ll/db_scripts:
    run folowing to create database
    $ sudo -u postgres createuser --pwprompt zabbix
    $ sudo -u postgres createdb -O zabbix zabbix
    $ sudo -i
    $ cd /usr/share/zabbix-server-pgsql
    $ gzip -d *.sql.gz
    $ cat schema.sql | sudo -u zabbix psql zabbix
    $ cat images.sql | sudo -u zabbix psql zabbix
    $ cat data.sql | sudo -u zabbix psql zabbix
    Can connect with
    $ PGPASSWORD=<pass> psql -d zabbix -U zabbix
    Then during install when I try to connect to DB I get 'The frontend does not match Zabbix database.''
  • rv_overseer
    • Jul 2014
    • 14
    You need to search the forum. There was a thread. It's a permission issue on the database tables. The zabbix user must be the owner for all those tables.
    • funkytwig
      • Jun 2016
      • 37
      I did a search on several things, including 'The frontend does not match Zabbix database.'
      It was actually when I entered zabbix as the schema when I got the above error. In fact, it seems everything is owned by public, if I miss out the scheme I simply get 'Unable to select configuration.'. A search for this here returns nothing;(.
      I then looked in the database for the tabels and think they are all there and are owned by zabbix:
      zabbix=# SELECT * FROM pg_catalog.pg_tables where tableowner = 'zabbix';
      schemaname | tablename | tableowner | tablespace | hasindexes | hasrules | hastriggers | rowsecurity
      public | screen_usrgrp | zabbix | | t | f | t | f
      public | screen_user | zabbix | | t | f | t | f
      public | groups | zabbix | | t | f | t | f
      public | slideshow_user | zabbix | | t | f | t | f
      public | screens_items | zabbix | | t | f | t | f
      public | slideshow_usrgrp | zabbix | | t | f | t | f
      public | screens | zabbix | | t | f | t | f
      public | slideshows | zabbix | | t | f | t | f
      public | httpstepitem | zabbix | | t | f | t | f
      public | httpstep | zabbix | | t | f | t | f
      public | interface | zabbix | | t | f | t | f
      public | valuemaps | zabbix | | t | f | t | f
      public | media_type | zabbix | | t | f | t | f
      public | opmessage | zabbix | | t | f | t | f
      public | actions | zabbix | | t | f | t | f
      public | opmessage_grp | zabbix | | t | f | t | f
      public | opmessage_usr | zabbix | | t | f | t | f
      public | config | zabbix | | t | f | t | f
      public | opconditions | zabbix | | t | f | t | f
      public | opcommand_grp | zabbix | | t | f | t | f
      public | opgroup | zabbix | | t | f | t | f
      public | optemplate | zabbix | | t | f | t | f
      public | conditions | zabbix | | t | f | t | f
      public | trigger_depends | zabbix | | t | f | t | f
      public | functions | zabbix | | t | f | t | f
      public | graph_theme | zabbix | | t | f | f | f
      public | globalmacro | zabbix | | t | f | f | f
      public | mappings | zabbix | | t | f | t | f
      public | hosts_groups | zabbix | | t | f | t | f
      public | hosts_templates | zabbix | | t | f | t | f
      public | items_applications | zabbix | | t | f | t | f
      public | services | zabbix | | t | f | t | f
      public | media | zabbix | | t | f | t | f
      public | rights | zabbix | | t | f | t | f
      public | sysmaps_links | zabbix | | t | f | t | f
      public | icon_map | zabbix | | t | f | t | f
      public | services_times | zabbix | | t | f | t | f
      public | sysmaps_link_triggers | zabbix | | t | f | t | f
      public | sysmaps_elements | zabbix | | t | f | t | f
      public | sysmap_element_url | zabbix | | t | f | t | f
      public | ids | zabbix | | t | f | f | f
      public | alerts | zabbix | | t | f | t | f
      public | regexps | zabbix | | t | f | t | f
      public | sysmap_usrgrp | zabbix | | t | f | t | f
      public | maintenances_hosts | zabbix | | t | f | t | f
      public | maintenances_groups | zabbix | | t | f | t | f
      public | timeperiods | zabbix | | t | f | t | f
      public | history | zabbix | | t | f | f | f
      public | history_uint | zabbix | | t | f | f | f
      public | history_str | zabbix | | t | f | f | f
      public | history_log | zabbix | | t | f | f | f
      public | history_text | zabbix | | t | f | f | f
      public | proxy_history | zabbix | | t | f | f | f
      public | proxy_dhistory | zabbix | | t | f | f | f
      public | trends | zabbix | | t | f | f | f
      public | trends_uint | zabbix | | t | f | f | f
      public | auditlog | zabbix | | t | f | t | f
      public | proxy_autoreg_host | zabbix | | t | f | f | f
      public | host_inventory | zabbix | | t | f | t | f
      public | escalations | zabbix | | t | f | f | f
      public | globalvars | zabbix | | t | f | f | f
      public | housekeeper | zabbix | | t | f | f | f
      public | service_alarms | zabbix | | t | f | t | f
      public | autoreg_host | zabbix | | t | f | t | f
      public | graph_discovery | zabbix | | t | f | t | f
      public | dhosts | zabbix | | t | f | t | f
      public | item_discovery | zabbix | | t | f | t | f
      public | dbversion | zabbix | | f | f | f | f
      public | slides | zabbix | | t | f | t | f
      public | group_prototype | zabbix | | t | f | t | f
      public | item_condition | zabbix | | t | f | t | f
      public | group_discovery | zabbix | | t | f | t | f
      public | maintenances | zabbix | | t | f | t | f
      public | usrgrp | zabbix | | t | f | t | f
      public | users | zabbix | | t | f | t | f
      public | hosts | zabbix | | t | f | t | f
      public | interface_discovery | zabbix | | t | f | t | f
      public | trigger_discovery | zabbix | | t | f | t | f
      public | profiles | zabbix | | t | f | t | f
      public | sessions | zabbix | | t | f | t | f
      public | application_template | zabbix | | t | f | t | f
      public | opinventory | zabbix | | t | f | t | f
      public | item_application_prototype | zabbix | | t | f | t | f
      public | application_prototype | zabbix | | t | f | t | f
      public | application_discovery | zabbix | | t | f | t | f
      public | sysmap_url | zabbix | | t | f | t | f
      public | scripts | zabbix | | t | f | t | f
      public | icon_mapping | zabbix | | t | f | t | f
      public | opcommand | zabbix | | t | f | t | f
      public | opcommand_hst | zabbix | | t | f | t | f
      public | httptest | zabbix | | t | f | t | f
      public | dchecks | zabbix | | t | f | t | f
      public | httptestitem | zabbix | | t | f | t | f
      public | sysmap_user | zabbix | | t | f | t | f
      public | host_discovery | zabbix | | t | f | t | f
      public | users_groups | zabbix | | t | f | t | f
      public | sysmaps | zabbix | | t | f | t | f
      public | graphs_items | zabbix | | t | f | t | f
      public | hostmacro | zabbix | | t | f | t | f
      public | items | zabbix | | t | f | t | f
      public | maintenances_windows | zabbix | | t | f | t | f
      public | expressions | zabbix | | t | f | t | f
      public | dservices | zabbix | | t | f | t | f
      public | services_links | zabbix | | t | f | t | f
      public | applications | zabbix | | t | f | t | f
      public | images | zabbix | | t | f | t | f
      public | events | zabbix | | t | f | t | f
      public | acknowledges | zabbix | | t | f | t | f
      public | triggers | zabbix | | t | f | t | f
      public | auditlog_details | zabbix | | t | f | t | f
      public | operations | zabbix | | t | f | t | f
      public | graphs | zabbix | | t | f | t | f
      public | drules | zabbix | | t | f | t | f
      (113 rows)
      (END)
      • funkytwig
        • Jun 2016
        • 37
        OK, looked like I had not done
        Have other issues but will start another thread.
        • rv_overseer
          • Jul 2014
          • 14
          On my postgresql database, I've got 140 tables in public for Zabbix 3.4
          zabbix=# SELECT * FROM pg_catalog.pg_tables where schemaname='public';
          public | dashboard_usrgrp | zabbix | | t | f | t | f
          (140 rows)
