I am using the Template Module ICMP Ping to try and ping our Windows servers. For some reason it is not working.
Zabbix Server
Zabbix Version: 3.4.4
Ubuntu 16.4.3 LTS
fping version: 3.13
Template
Type: Simple check
Key: icmpping
Update interval: 30s <-- Only thing I changed from the original template.
History: 1w
Storage: 365d
Show Value: As is
Application: Status
I can use fping from my terminal and can see that the servers are responding.
Any help is appreciated.
Zabbix Server
Ubuntu 16.4.3 LTS
fping version: 3.13
Template
Type: Simple check
Key: icmpping
History: 1w
Storage: 365d
Show Value: As is
Application: Status
