Zabbix SNMP Monitoring a HP J8697A Switch 5406zl with Software revision K.15.18.0013
  • Deicidium_
    • Dec 2017
    The SNMP Monitoring fails with Firewall up on the Zabbix Server
    Zabbix Server on CentOS 7.4
    There's my firewalld rules:
    <?xml version="1.0" encoding="utf-8"?>
    <service>
    <short>Zabbix Server</short>
    <description>Zabbix Server</description>
    <port protocol="udp" port="162"/>
    <port protocol="tcp" port="162"/>
    <port protocol="udp" port="161"/>
    <port protocol="tcp" port="161"/>
    <port protocol="tcp" port="6010"/>
    <port protocol="tcp" port="10052"/>
    <port protocol="udp" port="323"/>
    <port protocol="udp" port="31560"/>
    <port protocol="udp" port="8161"/>
    <port protocol="udp" port="1993"/>
    <port protocol="tcp" port="1993"/>
    <port protocol="udp" port="50248"/>
    <port protocol="udp" port="13371"/>
    <port protocol="tcp" port="13371"/>
    <port protocol="tcp" port="199"/>
    <port protocol="tcp" port="3306"/>
    <port protocol="tcp" port="80"/>
    <port protocol="tcp" port="443"/>
    <port protocol="tcp" port="10050"/>
    <port protocol="tcp" port="10051"/>
    <port protocol="udp" port="623"/>
    <port protocol="udp" port="624"/>
    </service>
    Thanks in regard
  • nelsonab
    • Sep 2006
    • 1233
    Why do you think it's a firewall issue?
    RHCE, author of zbxapi
