Log file monitor, not trigger upon duplicate lines
  • moshikoy
    • Aug 2017
    • 56
    I was wondering if there is a simple solution to exclude duplicate lines from triggering.
    Saying the same exact line appeared in the log file more than once.
    Can I add the log file trigger a comparison between item.value and item.value1 (see example below)
    example:
    take this:
    {Log File monitor Template:logrt[/var/log/syslog,@log_filter_syslog,,,skip].iregexp(@log_filter_syslog)}=1
    and make it into this:
    {Log File monitor Template:logrt[/var/log/syslog,@log_filter_syslog,,,skip].iregexp(@log_filter_syslog)}=1 and {ITEM.VALUE} != {ITEM.VALUE1}
    Not sure about the syntax..
    Is this a legal trigger?
    - Moshe
  • moshikoy
    • Aug 2017
    • 56
    found a solution:
    and {Log File monitor Template:logrt[/var/log/syslog,@log_filter_syslog,,,skip].diff()}=1
    In addition, I needed to set "OK event generation" to None, since the exact same line generate an OK event which is closing the first event
    Mosh
