PSK Encryption Help
  • monarch684
    • Oct 2017
    • 32
    PSK Encryption Help
    All,
    I am trying to setup PSK encryption but obviously doing something wrong. Here is the setup.
    DB: MySQL
    Zabbix Host (3.4.4)(Ubuntu 16.04.3 LTS) --> Zabbix Proxy (3.4.5)(Ubuntu 16.04.3 LTS) --> Zabbix Agent (3.0.4)(Windows Server 2012 R2)
    Firewall - None (This is a test environment.)
    For the Host Encryption I have the following: (This appears to be working)
    • Connections to host - No encryption
    • Connections from host - PSK
    • PSK Identity - PSK01
    • PSK - Very long key
    For the Proxy Encryption I have the following: (This appears to be working)
    • Connections to proxy - PSK
    • Connections from proxy - Grayed out. Cannot make a selection
    For the Agent Encryption I have the following: (This is not working. Cannot even start the service.)
    • Server=1.1.1.2 (Proxy)
    • ListenIP=1.1.1.1 (Agent)
    • TLS Connect - psk
    • TLS Accept - psk
    • TLSPSKIdentity - PSK01
    • TLSPSKFile - File location to zabbax_psk.psk
    When I make the changes to zabbix_agentd.win.conf, the service will not start. I am assuming that I missed a configuration or have too many set.
    I also ran WireShark and saw no encrypted traffic between any of the 3 configurations. I am a noob when it comes to WireShark so I could have misread something.
    Any help is greatly appreciated.
  • rthonpm
    • Jan 2016
    • 44
    The pre-compiled Zabbix Agents for Windows do not include TLS support. Right now, the only solution is to build your own version of the Windows agent with a TLS library.
    Hopefully, there will be pre-compiled versions with TLS coming from the Zabbix Team. It seems a little short-sighted to not have a version available.
    • monarch684
      • Oct 2017
      • 32
      Something new to learn......yay. I have never compiled the agents so this will be a new experience for me. Can I assume there are some instructions out there somewhere?
      • rthonpm
        • Jan 2016
        • 44
        This is the closest thing to an instruction set right now: https://support.zabbix.com/browse/ZBXNEXT-3047
        • monarch684
          • Oct 2017
          • 32
          That is the one I am currently looking at, so I guess I am going in the right direction. Thank you.
