Hi all,
I have a config with several proxies and one main server. Now for the first time I'd like to add a proxy that is not in the same LAN (S2S VPN) network. This works fine the proxy is reporting to the server. However a requirement was to run this server on a custom port. So I made a PAT rule in the firewall to make the server available on the internet side via this custom port but internally on 10050/10051 as per usual.
So the setup is this:
Zabbix server with standard ports
Port translate from external 20050 to 10050
Proxy, reporting to external internet IP of the server
How can I get the agents to behave in this setup and report to the proxy normally? They do not seem to have a connection. Any help will be great on this.
