Cannnot monitor IDRAC6 with IPMI
  • msalvatori
    • Mar 2017
    Got a zabbix server version 3.2.7 running on a centos 7, and I am trying to monitor a IDRAC 6 host with IPMI.
    In the IDRAC was created an user with admin privileges.
    The credentials for this user are ok.
    In zabbix server the host was created and this user credentials add to the IPMI tab. The authentication alg was set to MD5.
    Zabbix Server is returning the error:
    cannot connect to IPMI host: [16777411] Unknown error 16777411
    Here is result of running ipmitool from the server:
    Sending IPMI/RMCP presence ping packet
    Received IPMI/RMCP response packet:
    IPMI Supported
    ASF Version 1.0
    RMCP Version 1.0
    RMCP Sequence 255
    IANA Enterprise 4542
    ipmi_lan_send_cmdpened=[1], open=[2053345744]
    Channel 01 Authentication Capabilities:
    Privilege Level : ADMINISTRATOR
    Auth Types : MD2 MD5
    Per-msg auth : disabled
    User level auth : enabled
    Non-null users : enabled
    Null users : disabled
    Anonymous login : disabled
    Proceeding with AuthType MD5
    No response from remote controller
    Get Session Challenge command failed
    Error: Unable to establish LAN session
    Error: Unable to establish IPMI v1.5 / RMCP session
    Can anyone tell me what is wrong?
