Agent Not Allowing Connections
  • monarch684
    • Oct 2017
    • 32
    After getting help on another thread (https://www.zabbix.com/forum/showthread.php?t=60273) I was able to recompile the Agent to have TLS Support. I have everything up and running, finally. But I have one exception. The proxy cannot communicate with the Agent. I keep getting this:
    4604:20180103:152007.637 failed to accept an incoming connection: from 10.109.3.56: unencrypted connections are not allowed
    What do I need to check on the proxy to make sure I have everything in the proper places?
  • kaspars.mednis
    • Oct 2017
    • 349
    Hi !
    Is this the proxy log ?
    Two things must be configured for encryption to work
    - Proxy must accept encrypted connections (configuration->hosts->select host->encryption)
    - Encryption must be enabled and configured in zabbix_agentd.conf (zabbix agent restart needed after config changes.
    below are needed config settings on agent side for PSK encryption to work
    TLSPSKIdentity=yourPSKidentity
    TLSPSKFile=yourPSKfile
    TLSConnect=psk
    TLSAccept=psk
    Regards,
    Kaspars
    • monarch684
      • Oct 2017
      • 32
      Attached are my log files and conf files. I left debug on overnight on accident. Can you see if I mistyped something or completely fubared something.
      Just an FYI, this is running in a test environment. I chose not to scrub the usual sensitive data as it is going to change in the production environment.
      • kaspars.mednis
        • Oct 2017
        • 349
        you have the following entry in zabbix_agentd.win.conf.txt
        # TLSConnect=unencrypted
        because if that active agent is sending unencrypted data to zabbix proxy, and zabbix proxy has the following entry in log
        set it to psk and restart your agent
        TLSConnect=psk
        Regards,
        Kaspars
        • monarch684
          • Oct 2017
          • 32
          I made the change but still nothing. This is actually from the agent log.
          304:20180104:083237.196 failed to accept an incoming connection: from 10.109.3.56: unencrypted connections are not allowed
          • kaspars.mednis
            • Oct 2017
            • 349
            if this is agent log, zabbix proxy is trying to connect to agent with unencrypted connection.
            Have you set encryption settings in host configuration on web interface ? Also remember, it takes time for proxy to get config changes from Zabbix server
            Regards,
            Kaspars
            • monarch684
              • Oct 2017
              • 32
              Yes, encryption is turned on everywhere I could find.
              For the host:
              • Connections to host - PSK
              • Connections from host - PSK
              • PSK Identity is Set
              • PSK is Set
              For the proxy: PASSIVE
              • Connections to proxy PSK
              • Connections from proxy is grayed out. I have PSK checked but I think it might be inactive.
              • PSK is Set
              All these settings are what they were yesterday when I left work for the day.
              • kaspars.mednis
                • Oct 2017
                • 349
                Connections from proxy is grayed out because it is PASSIVE proxy and not connecting to Zabbix Server
                What is ProxyConfigFrequency= on Zabbix_server_conf ?
                Are there any errors regarding proxy_config update on zabbix_server_log ?
                Zabbix passive proxies wait for all config data to be sent from Zabbix server, maybe there is some issue ? The Zabbix proxy may just "don't know" about the encryption settings for the host.
                Regards
                Kaspars
                • monarch684
                  • Oct 2017
                  • 32
                  I am getting this error in the zabbix_server.log
                  cannot connect to proxy "Zabbix Proxy": TCP susscessful, cannot establish TLS to [IP ADDRESS]: connection closed by peer
                  ProxyConfigFrequency=300
                  I have a short amount of time just for testing purposes.
                  • kaspars.mednis
                    • Oct 2017
                    • 349
                    So there is problem with configuration update from ZabbixServer to ZabbixProxy, you must fix it first.
                    does the file TLSPSKFile=/etc/zabbix/zabbix_psk.psk persist on Zabbix proxy ?
                    Are the PSK identity and key correct in ZabbixServer->Administrtaion->proxies->thatProxy->encryption tab ? (they must match parameters defined in zabbix_proxy.conf
                    Regards
                    Kaspars
                    • monarch684
                      • Oct 2017
                      • 32
                      I did have one glaring issue. What was in the zabbix_psk.psk did not match anything. I have corrected that and rebooted the proxy. Is that something that I have to wait to see if I have corrected the issue or should it work almost instantly?
                      • kaspars.mednis
                        • Oct 2017
                        • 349
                        It must get new config after ProxyConfigFrequency=300 (5 minutes)
                        Just check the Zabbix Server / Proxy Logs.
                        After that if the host agent does not start to work, we can troubleshoot that.
                        Regards,
                        Kaspars
                        • monarch684
                          • Oct 2017
                          • 32
                          Still same error message
                          • monarch684
                            • Oct 2017
                            • 32
                            I just got through testing the encryption from server to agent, no proxy in the middle. Everything works as it should. That leads me to believe I have the proxy setup incorrectly or the server and agent going to the proxy setup incorrectly.
                            • monarch684
                              • Oct 2017
                              • 32
                              #15
                              Does anyone have an idea of what might be going on here?
