Problems Widget - Can you Disable Flashing of recent problems?
  • BSDUKJ
    • Aug 2017
    • 38
    I've configured my Dashboard to list the most recent problems.
    While I think the Flashing is good to highlight an issue colleagues find it distracting and I've been asked to try and find a solution.
    Is there an option to turn of the flashing to just a static colour like the rest of the items?
    Cheers
    Jay
  • allexpetrov
    • May 2017
    • 361
    Hi Jay,
    I think that Administration -> General -> Trigger displaying options could be the configuration page you are searching for.
    Just set On status change triggers blink for the parameter to 0 and this should do the trick.
    Regards,
    Alex!
    • BSDUKJ
      • Aug 2017
      • 38
      Top Man Alex!
      Top Man Alex!!
      Exactly what I was looking for.
      I'l see if they will comprimising to just 5 minutes blinking
      Cheers
      Jay
