Monitor Event Log for Event ID 208 and auto-close problem
  • TheCookieMonster
    • Jul 2017
    • 48
    Im trying to monitor the Windows Event Log for Event ID 208
    I have a Item:
    Name: Event Log: SQL Server Agent
    Type: Zabbix agent (active)
    Key: eventlog[Application,,,,208]
    Which looks to work as expected.
    And my trigger is currently:
    Name: Event Log: SQL Agent Job Failure
    Problem expression: {Server01:eventlog[Application,,,,208].logeventid(208)}=1
    My only problem is that I want this 'Problem' to be marked as Resolved in Zabbix pretty instantly, because there wont be a resolved entry in Windows Event Log for it to pick up on, does anyone know how I could do this?
  • mbribeiro@gmail.com
    • Jun 2018
    • 13
    I have the same problem. I have this
    {SERVER1:eventlog[Application,,,,15007,,skip].logeventid(15007)}=1
    and
    Recovery Expression
    {SERVER1:eventlog[Application,,,,15007,,skip].nodata(30)}=1 In my case the trigger stays forever as a problem, never getting resolved.
    • kernbug
      • Feb 2013
      • 329
      Hi
      You can use Zabbix API in conjunction of the ability to close problems manually from this document: https://www.zabbix.com/documentation.../manual_close3
      • Yvan
        • Apr 2018
        for the items, do you select log or text ?
        I got an error saying not supported but the info message display the event logs..
        • singk
          • Feb 2018
          you can try and put in this the Problem expression and do not use Recovery Expression.
          {SERVER1:eventlog[Application,,,,15007,,skip].logeventid(15007)}=1 and
          {SERVER1:eventlog[Application,,,,15007,,skip].nodata(30)}=0
          • Yvan
            • Apr 2018
            This works : {servername:eventlog[Application,,,,15004].logeventid(15004)}=1
            i tried to add that in recovery expression :
            {servername:eventlog[Application,,,,15005].logeventid(15005)}=1
            but it doesnt detect it so incident didnt close.
            Thanks for your help,
            • sinefile1
              • Mar 2019
              Hi! I know this is old post, but did anyone finds working solution on these issue?
