First of all, zabbix is a wonderfull monitoring software, we used it without any problem, until now.
Okay guys, before you ask, yes i searched the board and i think i tried every single solution on stackoverflow etc
I am pulling my hair out a few days now. I am using a zabbix server without about 30 clients and everything is working perfectly. Now i wanted to add a random linux machine to zabbix and it just wont work.
Setup:
Server: 3.2.8
Client: 3.2.11 on Debian 9
The funny part is, that i copied the zabbix_agent.conf from another working zabbix agent and just changed the hostname. (yes, the hostname is correct set as machine name and hostname, no differences here)
zabbig_agent.conf:
i added the client on the zabbix server at Configuration - Hosts - Create Host and entered the exact same hostname as in the config. i even checked the MySQL database on the server and checked if the hostname is correctly set.
the agent service starts without an error but on the server i never get any data. The agent logfile ( /var/log/zabbix-agent/zabbix_agentd.log) says:
I just dont get it. Did i forget to set something on the server? As i said, the exact same agent config works on all the other linux machines.
Setup:
Server: 3.2.8
zabbig_agent.conf:
PidFile=/var/run/zabbix/zabbix_agentd.pid LogFileSize=0 LogFile=/var/log/zabbix-agent/zabbix_agentd.log Server=192.168.99.17 ServerActive=192.168.99.17:10051 Hostname=MACHINE01
320:20180111:164744.197 Starting Zabbix Agent [MACHINE01]. Zabbix 3.2.11 (revision 76339). 320:20180111:164744.219 **** Enabled features **** 320:20180111:164744.219 IPv6 support: YES 320:20180111:164744.219 TLS support: YES 320:20180111:164744.219 ************************** 320:20180111:164744.219 using configuration file: /etc/zabbix/zabbix_agentd.conf 320:20180111:164744.222 agent #0 started [main process] 323:20180111:164744.250 agent #3 started[listener #2] 321:20180111:164744.253 agent #1 started [collector] 322:20180111:164744.255 agent #2 started[listener #1] 324:20180111:164744.268 agent #4 started[listener #3] 325:20180111:164744.274 agent #5 started [active checks #1] 325:20180111:164744.306 no active checks on server [192.168.99.17:10051]: host [MACHINE01] not found
