Export / Import problems...
  • Alfista
    • Mar 2017
    • 136
    I have exported all - Templates, Hosts, Screens, Maps from version 3.2 and now have problems with import to version 3.4.
    Hosts and Tempaltes are imported corectly, but the Maps and Screen will not import and still tell me that something is missing, like some graphs in screens and in maps is missing an iconmap.
    Please can you help me and tell me how can I import it that I dont need to create all again.
    Thanks for help.
  • kloczek
    • Jun 2006
    • 1771
    So what kind of error messages you see?
    • Alfista
      • Mar 2017
      • 136
      this is from Screen import:
      Import failed
      Details
      Cannot find graph "CPU Utilization" used in screen "Control PC 2".
      But thing there will be more, while this graphs was created manualy in more hosts.
      And by import maps:
      Import failed
      Details
      Cannot find icon map "RTVS_icon_map" used in map "RTVS Vlan 554".
      Is possible to import it and that it skip the problematic fields?
      Thanks.
      • Doreen654
        • Jul 2018
        You are working as an intermediary, you need to know and be confident in the buyers and sellers you represent. If you represent a small company that is unable to fill purchase orders or delivers a sub-standard product, you quickly lose credibility with your buyers.
