Anyone use HTTPS steps with SSL certificate file and SSL key file? is this working with Zabbix 3.4.4? I only get Couldn't connect to server: couldn't connect to host. with cURL command line tool all works smooth and with C binary that i've create works too but with zabbix there is no way always Couldn't connect to server: couldn't connect to host error
this is my sample code:
And this the curl command:
curl -kvL --cert cert.pem --key cert.key --pass XXXXXX -X GET "https://test:91/TEST/TESTService.svc?wsdl"
curl_easy_setopt(curl, CURLOPT_WRITEFUNCTION, WriteMemoryCallback);
curl_easy_setopt(curl, CURLOPT_WRITEDATA, (void *)&output);
curl_easy_setopt(curl, CURLOPT_URL, "https://test:91/TEST/TESTService.svc?wsdl");
curl_easy_setopt(curl, CURLOPT_SSL_VERIFYPEER, 0L);
curl_easy_setopt(curl, CURLOPT_SSL_VERIFYHOST, 0L);
curl_easy_setopt(curl, CURLOPT_SSLCERT, "./cert.pem");
curl_easy_setopt(curl, CURLOPT_SSLKEY, "./cert.key");
curl_easy_setopt(curl, CURLOPT_KEYPASSWD, "XXXXXX");
curl_easy_setopt(curl, CURLOPT_FOLLOWLOCATION, 1L);
curl_easy_setopt(curl, CURLOPT_USERAGENT, "Mozilla/4.0");
curl_easy_setopt(curl, CURLOPT_AUTOREFERER, 1 );
curl_easy_setopt(curl, CURLOPT_COOKIEFILE, "");
curl_easy_setopt(curl, CURLOPT_TIMEOUT, 15);
res = curl_easy_perform(curl);
curl_easy_getinfo (curl, CURLINFO_RESPONSE_CODE, &http_code);
