Quick help about a trigger for a service
  • sickflow1991
    • Jan 2018
    Hello everybody,
    I have a little problem with a trigger. I want to add it manually.
    This is the trigger :
    {Myhost:service.info[Sage_Syracuse_-_NODE0,state].min(#3)}<>0
    Zabbix doesn't want to add it (incorrect key). I check many times if there's a syntax problem but not, and when I change the service and use another one random (like FontCache) there's no problem.
    I think it's a problem with the - or the underscore. Could you help me please ? I can't rename the service (there's too many script which call this service).
