Zabbix Agent problems on Win 10.
  • Alfista
    • Mar 2017
    • 136
    i have many PC's which I monitor, and all I have Windows 7 with installed Zabbix Agent.
    No I have installed it on Windows 10 and can't start the comunication between Zabbix server and agent on client PC.
    I have this errors:
    8496:20180122:152256.986 **** Enabled features ****
     8496:20180122:152256.986 IPv6 support:          YES
     8496:20180122:152256.986 TLS support:            NO
     8496:20180122:152256.986 **************************
     8496:20180122:152256.986 using configuration file: c:\ZABBIX\conf\zabbix_agentd.win.conf
     8496:20180122:152257.001 In init_collector_data()
     8496:20180122:152257.001 End of init_collector_data()
     8496:20180122:152257.001 In init_perf_collector()
     8496:20180122:152257.001 End of init_perf_collector():SUCCEED
     8496:20180122:152257.001 agent #0 started [main process]
     7808:20180122:152257.001 agent #1 started [collector]
     6196:20180122:152257.001 agent #2 started[listener #1]
     6400:20180122:152257.001 agent #3 started[listener #2]
     9372:20180122:152257.001 agent #4 started[listener #3]
     8032:20180122:152257.001 agent #5 started [active checks #1]
     7808:20180122:152257.001 In init_cpu_collector()
     8032:20180122:152257.001 In init_active_metrics()
     7808:20180122:152257.001 In get_counter_name() pdhIndex:238
     8032:20180122:152257.001 buffer: first allocation for 100 elements
     8032:20180122:152257.001 End of init_active_metrics()
     8032:20180122:152257.001 In send_buffer() host:'192.168.51.232' port:10051 entries:0/100
     8032:20180122:152257.001 End of send_buffer():SUCCEED
     8032:20180122:152257.001 In refresh_active_checks() host:'192.168.51.232' port:10051
     8032:20180122:152257.001 sending [{"request":"active checks","host":"TRANSFERPC"}]
     8032:20180122:152257.001 before read
     8032:20180122:152257.017 got [{"response":"failed","info":"host [TRANSFERPC] not found"}]
     8032:20180122:152257.017 In parse_list_of_checks()
     8032:20180122:152257.017 no active checks on server [192.168.51.232:10051]: host [TRANSFERPC] not found
     8032:20180122:152257.017 End of parse_list_of_checks():FAIL
     8032:20180122:152257.017 End of refresh_active_checks():SUCCEED
     8032:20180122:152257.017 In process_active_checks() server:'192.168.51.232' port:10051
     8032:20180122:152257.017 End of process_active_checks()
     8032:20180122:152257.017 In get_min_nextcheck()
     8032:20180122:152257.017 End of get_min_nextcheck():-1
     7808:20180122:152257.254 End of get_counter_name():SUCCEED
     7808:20180122:152257.254 In get_counter_name() pdhIndex:6
     7808:20180122:152257.254 In add_perf_counter() counter:'\Processor(_Total)\% Processor Time' interval:900
     7808:20180122:152257.254 add_perf_counter(): PerfCounter '\Processor(_Total)\% Processor Time' successfully added
     7808:20180122:152257.254 End of add_perf_counter(): SUCCEED
     7808:20180122:152257.254 In add_perf_counter() counter:'\Processor(0)\% Processor Time' interval:900
     7808:20180122:152257.254 add_perf_counter(): PerfCounter '\Processor(0)\% Processor Time' successfully added
     7808:20180122:152257.254 In add_perf_counter() counter:'\Processor(1)\% Processor Time' interval:900
     7808:20180122:152257.254 add_perf_counter(): PerfCounter '\Processor(1)\% Processor Time' successfully added
     7808:20180122:152257.254 In add_perf_counter() counter:'\Processor(2)\% Processor Time' interval:900
     7808:20180122:152257.254 add_perf_counter(): PerfCounter '\Processor(2)\% Processor Time' successfully added
     7808:20180122:152257.254 In add_perf_counter() counter:'\Processor(3)\% Processor Time' interval:900
     7808:20180122:152257.254 add_perf_counter(): PerfCounter '\Processor(3)\% Processor Time' successfully added
     7808:20180122:152257.254 In get_counter_name() pdhIndex:2
     7808:20180122:152257.254 In get_counter_name() pdhIndex:44
     7808:20180122:152257.254 In add_perf_counter() counter:'\System\Processor Queue Length' interval:900
     7808:20180122:152257.254 add_perf_counter(): PerfCounter '\System\Processor Queue Length' successfully added
     7808:20180122:152257.270 End of add_perf_counter(): SUCCEED
     7808:20180122:152257.270 End of init_cpu_collector():SUCCEED
     7808:20180122:152257.270 In collect_perfstat()
     7808:20180122:152257.270 End of collect_perfstat()
     8032:20180122:152258.036 In send_buffer() host:'192.168.51.232' port:10051 entries:0/100
     8032:20180122:152258.036 End of send_buffer():SUCCEED
     7808:20180122:152258.285 In collect_perfstat()
     7808:20180122:152258.285 End of collect_perfstat()
     8032:20180122:152259.051 In send_buffer() host:'192.168.51.232' port:10051 entries:0/100
     8032:20180122:152259.051 End of send_buffer():SUCCEED
     7808:20180122:152259.301 In collect_perfstat()
     7808:20180122:152259.301 End of collect_perfstat()
     8032:20180122:152300.062 In send_buffer() host:'192.168.51.232' port:10051 entries:0/100
     8032:20180122:152300.062 End of send_buffer():SUCCEED
     7808:20180122:152300.314 In collect_perfstat()
     7808:20180122:152300.314 End of collect_perfstat()
     8032:20180122:152301.064 In send_buffer() host:'192.168.51.232' port:10051 entries:0/100
     8032:20180122:152301.064 End of send_buffer():SUCCEED
     7808:20180122:152301.330 In collect_perfstat()
     7808:20180122:152301.330 End of collect_perfstat()
     8032:20180122:152302.080 In send_buffer() host:'192.168.51.232' port:10051 entries:0/100
     8032:20180122:152302.080 End of send_buffer():SUCCEED
    Server, ServerActive IP addresses and hostname are set corectly, as on the all other PC's
    Please can any one help me where is the problem and resolve it?
    Thanks.
  • rthonpm
    • Jan 2016
    • 44
    Do you have an exception in the Windows firewall for your Zabbix server?
    • Alfista
      • Mar 2017
      • 136
      I have turned Firewall off, but will chcek it and add also.
      But As I look have the same settings on all other machines too included firewall.
      • Alfista
        • Mar 2017
        • 136
        It helps.
        I have opened ports for Zabbix agent, but it looks like Win 10 has something additionaly blocked. After turning off completly the Firewall it started working.
        Can you tell me which ports and which protocols use the Zabbix aggent, that the next time I can better check it?
        Thanks.
        • SirRasor
          • Feb 2019
          I found 2 things when I ran into this problem:
          1. Virus+firewall caught it -> solved, but still not working..
          2. Windows SmartScreen...goddamnit. Try to run manually zabbix_agentd.exe and if something blocks it, you will know instantly
          Hope this helps
