monitor/graph ipaddr changes to interface
  • me2017
    • Apr 2017
    • 34
    I have a UserParameter that returns an ip address from a given interface. I'd like to use some method of tracking 1) the address itself, 2) how long that address was applied / when it changed.
    I've tried using the following in the Item configuration but no graph is being produced. Indeed, I didn't fully expect this to work.
    Type of information: Numeric (unsigned)
    Data type: Octal
    I realize this may be a bit unconventional and may not be within the realm of Zabbix's capabilities. If you have seen a visualization of something like this I'd like to know how it might be done (eg, various Grafana plugins, some other network monintoring tool, etc).
  • me2017
    • Apr 2017
    • 34
    I realize this may be an unconventional question but I'd appreciate comments with regards to ways to deal with this issue. Yes I have logs but I'd like to find a means of using other visualizations.
    • kaspars.mednis
      • Oct 2017
      • 349
      You can monitor the address itself as a char type item (because 127.0.0.1 is not an integer or octal , it is interpreted as a string value by Zabbix).
      Then you can create second calculated item with diff function:
      And use some trigger if diff function returns 1.
      You can graph this calculated item, there will be straight line with spikes from 0 to 1 on each IP address change.
      Regards,
      Kaspars
      • me2017
        • Apr 2017
        • 34
        This is helpful, thank you. The method you've described will tell me WHEN (and IF) it changed, but it doesn't tell me what it CHANGED TO.
        I wonder if this is possible in Zabbix...
        Is there a means of providing some sort of visualization (a graph or other) that would reflect the following:
        Thu Jan 25 20:30:02 PST 2018, 184.66.191.2
        Thu Jan 25 21:30:01 PST 2018, 184.66.191.2
        Thu Jan 25 22:30:01 PST 2018, 184.66.190.45
        Thu Jan 25 23:30:02 PST 2018, 184.66.77.202
        Fri Jan 26 00:30:01 PST 2018, 184.66.77.202
