Considering moving from Xymon to Zabbix, some questions
  • telecaster
    • May 2017
    I currently use Xymon. Xymon is a very interesting monitoring software. It can be considered very outdated, especially if considering the UI stuck in the 80's. However, it's lightweight, feature packed, very flexible, easy to work with and very very stable. I didn't even knew it existed until two years ago, but kinda of inherited it and quickly grew fond of it once I could see past the nasty UI.
    But I want to leverage more advanced features that Xymon doesn't have and probably never will. Things like tags, built in correlation, dependencies, more flexible UI for dashboards and custom screens, offload of history data to external databases (or Elastic at least), integrated SNMP support, integrated IPMI, REST API, prediction and time shift analyis, etc.
    However, there are some things in Xymon which I'm failing to find a match in Zabbix, and could use some help with that. For example:
    1) In Xymon you can select a test for a particular host in a particular page, and disable notifications for that test temporarily, as in one of 1) for x period of time from now, 2) until a certain date 3) until the test is OK again. Until the condition is met, no alert is generated for the problem. Is this doable somehow in Zabbix?
    2 With the Xymon client utility, you can push the status level (red, yellow, green), a descriptive text block, and a expiry time for the status (expired is another status level in itself). You can then define on the server expressions to alert on the status level, only if the status is lasting for a certain period. Can such logic be implemented in Zabbix? And is there some way to define status right from the client.
    3) The message block reported with the Xymon client utility can be very large, up to 32KB. It enables very detailed problem descriptions when using custom scripts). Clicking on the item then displays the last message, and gives access to the history of the item, showing how long it lasted in each state transition, and you can also see the last message of each transition. This is very useful to understand behaviour of the monitored item. Is this possible somehow with Zabbix?
    4) With Xymon you can very quickly define placeholders for some test items (one line in a text file for each item), and then report from arbitrarily named "hosts" for those items. For example, a script can query a DB or something, check some condition, and report item check results for any number of host+test pairs. A single page can then show a matrix based layout with the status of each item for each "host". It's simple and effective. Can this be done with Zabbix somehow?
    5) Xymon is very easy to integrate with configuration management tools such as Puppet, because it just relies in 3 main text files. hosts, analysis and alerts. On the other hand, Zabbix seems to be very DB and UI dependent, and keeping conffiguration state via the REST API may be extremely heavy once you enter the hundreds of hosts and thousands of items realm. Are there success stories or best practices in managing medium level zabbix installations with configuration management tools like Puppet or Chef?
    6) Is it possible to publish in real time item status changes to an external interface (a script or a REST API)? Not necessarily history data, but just state transitions.
    That's already a handful of questions. Hope someone has some insights to help with the choice, thanks in advance!
  • kaspars.mednis
    • Oct 2017
    • 349
    i will try to answer your questions shortly:
    1. Its called host maintenance; https://www.zabbix.com/documentation...al/maintenance
    2. In Zabbix you use trigger severity https://www.zabbix.com/documentation...ggers/severity
    the same alert logic can be implemented with Zabbix, severity are defined from Zabbix server interface, not agent. By you can define different severity on different hosts (prod/dev) etc;
    3. Zabbix alert messages are very customisable, lots of macros can be used in messages (host name, date, item values etc);
    4. I do not fully understand your question, but Zabbix uses templates on hosts, you define one test and then assign this test to multiple hosts, all are reporting values, values can be displayed on one screen;
    5. Hundreds of hosts can be easy managed with the Zabbix built in interface, if you need some specific mass-update functions, then you can use API;
    6. Zabbix supports scripts on item status changes;
    You can download the Zabbix appliance and play with it https://www.zabbix.com/documentation...nual/appliance
    Or you can contact our sales team and request a live demo
    Regards,
    Kaspars
    • bbrendon
      • Sep 2005
      • 873
      Some good questions...
      1. No. Zabbix does it based on host or group of hosts. You could probably get creative and add macros or something to your triggers to invent a way but it's not built in.
      2. I'll just say no. The status is based on the trigger which is configured by the admin. You would have to get very creative here to do that. Doesn't sound feasible.
      3. I'm not sure what the text limits using the built in templates but I think most people who have advanced setups do the alerting with scripts. Once you are in a script that sends email you can attach graphs, link back to zabbix, pull other data into the email.
      4. I'll just say zabbix_sender allows to dump blocks of data into zabbix and the overview screen is the only matrix I believe. Or maybe reports? I have removed the overview parts of the GUI from my setup as I never liked them and don't want questions about it from people. Try it out, maybe its what you're looking for.
      5. Discovery might help here and the API. Push the agent with Saltstack/puppet and a small agent config. Do as much of the configuration from zabbix as possible so you don't have to manage extra userparamaters or script on the agent ends.
      6. Yea. Simple db query or API call. Also, some 3rd party tools already have zabbix support in them.
      Unofficial Zabbix Expert
      Blog, Corporate Site
