External scripts not working post upgrade
  • zabbixfk
    • Jun 2013
    • 256
    Hi All,
    I just upgraded to 3.0.13, and it seems all of my external scripts broken.
    I had this configurations.
    under '/etc/zabbix/externalscripts' and '/usr/local/share/zabbix/externalscripts' i had some scripts which are basically shell script wrappers intern calls expect ( tcl) scripts to go into devices and pull some data.
    For example.
    cat /usr/local/share/zabbix/externalscripts/rf_index
    #!/bin/bash
    val=$(/usr/bin/expect '/usr/local/etc/scripts/rf_index.exp' $1  | grep 'Index =' | cut -d'=' -f3 | sed -e's/\s//g')
    echo "$val"
    and cat /usr/local/etc/scripts/rf_index.exp has
    #!/usr/bin/expect
    set host "XXX.XXX.XXX.XX"
    set uname "XXXXX"
    set pwd "XXXXX"
    set prompt "#|>|:|\\\$";
    set val ""
    set domain [lindex $argv 0]
    log_user 0
    set timeout -1
    spawn /usr/bin/ssh "$uname@$host"
    expect "$uname@$host's password:"
    send "$pwd\n"
    sleep 1
    #expect -re "$prompt"
    expect ">"
    sleep 1
    send "show wireless rf-domain statistics detail on $domain | grep Index\r"
    sleep 1
    expect  ">"
    set val $expect_out(buffer)
    send "exit\n"
    puts $val
    This use to work with below paramerts on item configurations.
    Name : RF-Index - DOMAIN_NAME
    Type: External Check
    Key : rf_index["DOMAIN_NAME"]
    Host interface: IP:PORT  ( this does not matter as i am going to monitor this via zabbix_proxy, and this will be running in zabbix_porxy)
    Type of information: Numeric(unsigned)
    Data type: Decimal
    Now, when i see items page, i am seeing timeout errors. - 'Timeout while executing a shell script' and log does show getting this script called, and sends
    30398:20180203:144406.037 In substitute_key_macros() data:'rf_index[" DOMAIN_NAME"]'
     30398:20180203:144406.037 End of substitute_key_macros():SUCCEED data:'rf_index["DOMAIN_NAME"]'
     30398:20180203:144406.037 In get_value() key:'rf_index["DOMAIN_NAME"]'
     30398:20180203:144406.037 In get_value_external() key:'rf_index["DOMAIN_NAME"]'
     30398:20180203:144406.037 In zbx_popen() command:'/usr/local/share/zabbix/externalscripts/rf_index "DOMAIN_NAME"'
     30398:20180203:144406.038 End of zbx_popen():6
     25513:20180203:144406.038 zbx_popen(): executing script
    30473:20180203:144433.026 Item [HOST_NAME:rf_index["DOMAIN_NAME"]] error: Timeout while executing a shell script.
     30473:20180203:144433.026 End of get_value():NOTSUPPORTED
    Some has below error as well
     30406:20180203:144433.027 End of get_value_external():NOTSUPPORTED
     30406:20180203:144433.027 Item [HOST_NAMR:rf_index["DOMAIN_NAME"]] error: Received value [send: spawn id exp3 not open    while executing"send "$pwd\n""    (file "/usr/local/etc/scripts/rf_index.exp" line 12)] is not suitable for value type [Numeric (unsigned)] and data type [Decimal]
     30406:20180203:144433.027 End of get_value():NOTSUPPORTED
    Basically all i wanted is, run some scripts and display outputs - because using SNMP or via zabbx_agent as i can't either install zabbix_agent on those machines (routers/diff OS), or SNMP gets not supported.
    Any pointers to solve this greatly helpful.
    Thanks.
  • zabbixfk
    • Jun 2013
    • 256
    Please help
    *bump*
    Can someplease reply here - majority of my items which are monitored via external scripts are broken. Not able to figure out where and what is the issue.
    • Atsushi
      • Aug 2013
      • 2028
      Has timeout occurred in script execution?
      Please tell me how many seconds it takes to execute the script.
      If it is the default, it will time out in 3 seconds, so please specify a longer time to 'Timeout' in the setting file(zabbix_server.conf).
      • zabbixfk
        • Jun 2013
        • 256
        Thanks for the reply.
        I am not sure why/how timeouts are occurring. My time outs are set 30s from config file.
        Any pointers are greatly helpful.
        • Atsushi
          • Aug 2013
          • 2028
          Have you upgraded Zabbix on the same server that was working previously?
          Have you manually executed the script and got the value?
          Perhaps you are building a new version of Zabbix environment on another server?
          If you built it on another server, did you connect using the ssh command and added it to known_hosts?
          • zabbixfk
            • Jun 2013
            • 256
            Yes, i upgraded the servers, and all other things works just fine on the same machine.
            Well i had exectuted on the previouse version ( 2.2.12) and got the value. But after you ask, i run it again. Seeing this error
            Calling the wrapper shell script which is added as item in zabbix , which goes to some kind of loop.
            [root@zbx-proxy2 ~]# su - zabbix /usr/local/etc/scripts/rf_index DOMAIN_NAME
            ^C[root@zbx-proxy2 ~]#
            Then i called the inside expect(tcl) script which gives me the exact value, but looks like its not working either.
            [root@zbx-proxy2 ~]# su - zabbix /usr/bin/expect /usr/local/etc/scripts/rf_index.exp
            /usr/bin/expect: /usr/bin/expect: cannot execute binary file
            But when i run them as root it gives me values, something is changed or strange which i am not able to figure out.
            Thanks.
            • zabbixfk
              • Jun 2013
              • 256
              *Bump*
              Can some please reply here. I am stuck with these external script problems.
              Any pointers are greatly appreciated.
              • zabbixfk
                • Jun 2013
                • 256
                *Bump*
                • zabbixfk
                  • Jun 2013
                  • 256
                  External scripts broken
                  *bump*
                  Interesting as in even after 200 views to this thread, none has reply.
                  Zabbix team, please help. Most of my items are of external scripts stuff and they are broken.
                  Please share any pointers.
                  Thanks.
                  • zabbixfk
                    • Jun 2013
                    • 256
                    *Bump*
                    • SBO
                      • Sep 2015
                      • 226
                      The thing is, this is a system error, not a zabbix error, that's why you don't get that many answers.
                      If your script runs as root but not as zabbix, there's some permission issue somewhere.
                      Did you try to run the script with your user, to check if it's still working well ?
                      • zabbixfk
                        • Jun 2013
                        • 256
                        Thank you very much for the reply. Hope you have gone through the thread.
                        Do you see any abnormality in calling external scripts?
                        All the scripts , system executables such as expect, sed, cut have execute and read permissions.
                        Do you see any issue with permissions? What's the starting point for debug?
                        This use to work when i was in 2.2.12 build, now its upgraded to 3.0.13 and i am having issues ( timeout occurred - coz as a zabbix user its not possible to call external script which is having expect.)
                        • zabbixfk
                          • Jun 2013
                          • 256
                          *bump*
                          Can someone point out where's the error? Majoriry of my items are external scripts - and they seem to be broken.
                          • zabbixfk
                            • Jun 2013
                            • 256
                            *bump*
                            Any pointers to debug this is greatly helpful.
                            • kloczek
                              • Jun 2006
                              • 1771
                              #15
                              Instead fighting with external script you can use "SSH agent" item type.
