Custom Script to remove host
  • TheCookieMonster
    • Jul 2017
    • 48
    Im wondering if this is possible...
    I have hosts auto register, and when these hosts go offline I was them removed from Zabbix
    I had an Item doing Agent Ping, so I can tell when the host goes offline
    I can do a trigger that goes off if the ping has no data for 5 minutes
    I would like to do an action, with an operation as follows:
    Operation Type: Remote Command
    Type: Custom Script
    Execute On: Zabbix Server
    Now what I want this script to do, is to delete this host from Zabbix.
    But thats this bit im not sure on how to write...
    Any suggestions?
    Do I need to write the script to use the API to delete the host? or is there an alternative and easier way?
  • kaspars.mednis
    • Oct 2017
    • 349
    There is no easy way, you can vote for this feature here
    And here is some community made script to remove hosts
    Regards,
    Kaspars
