The bitwise and function (band()) works good in triggers.
When I want to use it in a calculated item for normalizing monitored items I can't get is to work. What I think de syntax must be for filtering the lowest 16 bits of a value:
This however doesn't work. I've tried several related versions of this but I can't get is to work!
What is the correct code to do this?
Btw: I need this for an item prototype (discovery thing)
band("item.key",65535)
