HP UX Memory Monitoring
  • Malarvizhi
    • Jan 2018
    I'm trying to monitor Memory of HP UX system using vm.memory.size[]. But it is not returning the exact values. Kindly suggest the other available options.
    Note : Version of Zabbix 2.0.9
  • Atsushi
    • Aug 2013
    • 2028
    What kind of arguments are specified?
    Depending on the platform, there are options that can not be used.
    Please check the manual for available options.
    Manual:
    • Malarvizhi
      • Jan 2018
      Thanks for your reply.
      vm.memory.size[free] is supported in HP UX. But the value returned via this parameter seems to be different then the output of swapinfo command. Kindly suggest.
      • Atsushi
        • Aug 2013
        • 2028
        FREE in swapinfo's output is the size of the free space in the swap area, is not it?
        vm.memory.size[free] should return free space in physical memory, not free space in the swap area.
        What value of swapinfo output compare?
        What is the difference?
        Please also compare with the output of the top command.
