Difference between #IFDESCR and #IFNAME
  • RonaldMcDonaldTrump
    • Jan 2018
    • 41
    I'm trying to apply a filter on a discovery rule based on interface name to a group of hosts .
    I'm getting confused about the accurate meaning of this expressions.
    Anyone can tell me?
  • Atsushi
    • Aug 2013
    • 2028
    How do you set the SNMP OID of the discovery rule?
    Have you specified the same OID for {# IFDESCR} and {# IFNAME}?
    If the OIDs are the same, they will be referring to the same value.
    When creating a template, I think that it would be better to unify so that either one is used.
