Fresh Install Issue
  • mw72
    • Feb 2018
    Fresh Install Issue
    Dear All,
    As a Linux novice i'd appreciate some help.
    This is the first time I have tried to install Zabbix from scratch.
    I have extremely minimal Linux skills.
    I have configured a Centos 7 64bit VM
    I have followed the install guide in the Zabbix documentation
    and successfully downloaded 3.4.6
    I have done the Yum Install of the 3 main Zabbix components
    but when I try to create the initial database
    MySQL -uroot -p it tells me "command not found"
    I have checked and there is a MySQL directory
    under lib64
    can anybody give me some pointers as to where I may be going wrong
    bearing in mind my Linux skills are very minimal ?
    M
  • Atsushi
    • Aug 2013
    • 2028
    The mysql command is all lowercase.
    ex.
    # mysql -uroot -p
    • tcilmo
      • Nov 2016
      • 122
      Since you did not specifically mention it, did you install MySQL first?
      • mw72
        • Feb 2018
        Database
        I was unable to install MySQL
        I found another post with regard to mariaDB
        which I then installed via YUM
        but I appear to have now broken my yum access as it just says the repo base code is no longer available
        Think I will have to wipe and start again
        Does anyone have a FULL end to end install guide that does not make assumptions on Linux knowledge or assume anything has been previously installed configured ?
