Zabbix Won't Stay Running
  • tcilmo
    • Nov 2016
    • 122
    #16
    Originally posted by emonhello
    I disabled the Router discovery that wasn't working.
    Also the SNMP piece of the VMware dicovery rule was throwing an error. I removed the SNMP piece of discovery.
    I have restarted the server. I will post back if it crashes, or tomorrow if it doesn't.
    Just came across this - If you are not on 3.4.7, try an upgrade.
    The release notes here: https://www.zabbix.com/rn/rn3.4.7
    show this bug fix:ZBX-13441 fixed crashes in case of failures (e.g. timeouts) during VMware hypervisor discovery
    • emonhello
      • Jan 2018
      • 18
      #17
      https://support.zabbix.com/browse/ZBX-13441
      Crashed again last night. This looks very promising.
      Thank you! Your help is greatly appreciated. I will post back after upgrade.
      • emonhello
        • Jan 2018
        • 18
        #18
        Updated
        I have updated to 3.4.7.
        I will post back with an update.
        • tcilmo
          • Nov 2016
          • 122
          #19
          Will do - hope that fixed ya!
          • emonhello
            • Jan 2018
            • 18
            #20
            No good
            Still not running. I will take a look at the logs and post back.
            • emonhello
              • Jan 2018
              • 18
              #21
              No luck
              Same problem. Log says out of memory - please increase VMwareCacheSize configuration parameter
              When I look at the cache graphs they are all nearly empty.
              Maybe I did something wrong in the initial setup. I did the discovery through Vcenter. I may just delete the hosts, and not include VCenter in the initial discovery.
              Frustrated. I am very new to zabbix, but it sure seems like the log should point me to the issue. I just don't see it.
