Zabbix + InfluxDB
  • Cain
    • Feb 2018
    Zabbix + InfluxDB
    Hi guys,
    Could I use the influxDB combined with Zabbix for storage monitoring logs?
    I do not want to use MySQL or MongoDB.
    I have tried to search this to the Google, but no any articles in this.
  • jan.garaj
    • Jan 2010
    • 506
    InfluxDB is not designated for logs. It will be very hackish if you will use it for logs.
    Elasticsearch is the best tool for logs. And it has also experimental support in Zabbix - https://www.zabbix.com/documentation...c_search_setup
    • Seqway
      • Jan 2022
      • 9
      i know it is a long time ago but i have a running InfluxDB available and i would be keen to store zabbix values in InfluxDB. Is there still no possibility to store the data in Influx ?
      Is Elasticsearch as fast as the real time database Influx ?
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        You might want to check out https://www.zabbix.com/integrations/influxdb
