I'm new in zabbix, learn to work with it and I have downloaded a new temlate "SNMP MegaRAID SAS" from the zabbix repository and installed it in Zabbix 3.4.5 appliance. I have also added a new MIB file which was neccessery to work with the template. I have placed it to MIBs folder, added it to the snmp.conf and it looks like that all is fine, no errors about this added MIB file. But when I look in Zabbix I have error "Not Supported - Cannot Parse OID", but I check it and these IOD's are there. Then I checked all over snmpwalk, but I don't receive any inforamation from local zabbix SNMP, only "Timeout" error. I have check all settings, set it corectly, but no change.
Please can anyone help me where can be the problem?
Thanks.
Thanks.
