And fcFxPortInvalidCrcs, fcFxPortInvalidTxWords, fcFxPortLinkFailures, fcFxPortSyncLosses, fcFxPortC1InOctets, fcFxPortC1OutOctets, etc.
I create items (for every port) in template (fc_switch_t):
Description: fcFxPortSigLosses port 1
Type: SNMPv1
SNMP community: public
SNMP OID: .1.3.6.1.2.1.75.1.3.1.1.3.1.1
SNMP port: 161
Key: fcFxPortSigLosses.1.1
Type of information: Integer64
Update interval (in sec): 900
Keep history (in days): 7
Keep trends (in days): 365
Store value: Delta (simple change)
And trigger
Name: fcFxPortSigLosses.1.1 on {HOSTNAME} has changed.
Expression: {fc_switch_t:fcFxPortSigLosses.1.1.last(0)}>0
