monitoring file exist
  • developerlearn999
    • Feb 2018
    • 9
    i want to monitor if file exist or not (error on some system)
    what do i need to to do to monitor it?
    add trigger?do some setting on agent?
    can some one explain step by step?
    thanks for any help
  • tcilmo
    • Nov 2016
    • 122
    thanks for any help
    We use the sumd5sum item. This example is 3-fold. We monitor for a file change, if the file is missing, and if the item is not recieving data (broken monitoring).
    Here are the trigger expressions.
    1) File Changed: {sumd5sum[path_to_file].diff()}=1}
    2) No data or Missing File: {sumd5sum[path_to_file].nodata(60m)}=1 or sumd5sum[path_to_file].strlen()}=0}
    Hope this helps!
    • developerlearn999
      • Feb 2018
      • 9
      how and where do i set it?
      what to configure on server and what on client?
      • tcilmo
        • Nov 2016
        • 122
        You have to configure the items and triggers on the host in Zabbix or with a template and then apply it to the hosts to monitor. These are Zabbix agent keys.
        • developerlearn999
          • Feb 2018
          • 9
          why i can configure this on agent
          i tried to define on agent
          vfs.file.exists[/tmp/application.pid]
          and the agent don't start until i remove it.
          do i need to add something else?
          • tcilmo
            • Nov 2016
            • 122
            The item type to use is Zabbix agent or Zabbix Agent Active. This is configured though the GUI. No need for a user parameter.
            • developerlearn999
              • Feb 2018
              • 9
              agent active
              if i want to make it when agent active i dont need to define
              anything on the agent side?
              i saw it on this part and i thought i should it on client side :
              ############ ADVANCED PARAMETERS #################
              ### Option: Alias
              # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
              # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
              # Different Alias keys may reference the same item key.
              # For example, to retrieve the ID of user 'zabbix':
              # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.[0-9]+),,,,\1]
              # Now shorthand key zabbix.userid may be used to retrieve data.
              • tcilmo
                • Nov 2016
                • 122
                nope - don't do that.
                • developerlearn999
                  • Feb 2018
                  • 9
                  i am looking for a "scenario"
                  which explain the relation between application->template->item->trigger
                  how to build it from Zero and so on
                  did you saw maybe some article about it?
                  • suhail
                    • Sep 2019
                    im new to zabbix,
                    i like to create an Action, to delete Host Temp files in windows every 20 days automatically.
                    can someone please guide me? and teach how to create actions?
                    this below commands i like to run
                    Del /S /F /Q %temp% (This clears the Userprofile Temp folder).
                    Del /S /F /Q %Windir%\Temp (This clears the Windows temp folder.)
                    i already enabled Remote commands in Agent.config
                    • Rudlafik
                      • Nov 2018
                      • 168
                      I set on windows system on folder properties - security - auditing. And than control security log for specific event. In ZBX i set control log file an regexp event filter.
