my last upgrade to zabbix 3.4 failed ,
The database cannot upgraded :
this is the logs :
6963:20180306:160307.546 Starting Zabbix Server. Zabbix 3.4.7 (revision 77720).
6963:20180306:160307.546 ****** Enabled features ******
6963:20180306:160307.546 SNMP monitoring: YES
6963:20180306:160307.546 IPMI monitoring: YES
6963:20180306:160307.546 Web monitoring: YES
6963:20180306:160307.546 VMware monitoring: YES
6963:20180306:160307.546 SMTP authentication: YES
6963:20180306:160307.546 Jabber notifications: YES
6963:20180306:160307.546 Ez Texting notifications: YES
6963:20180306:160307.546 ODBC: YES
6963:20180306:160307.546 SSH2 support: YES
6963:20180306:160307.546 IPv6 support: YES
6963:20180306:160307.546 TLS support: YES
6963:20180306:160307.546 ******************************
6963:20180306:160307.546 using configuration file: /etc/zabbix/zabbix_server.conf
6963:20180306:160307.554 current database version (mandatory/optional): 03010002/03010002
6963:20180306:160307.554 required mandatory version: 03040000
6963:20180306:160307.554 optional patches were found
6963:20180306:160307.555 [Z3005] query failed: [1091] Can't DROP 'id'; check that column/key exists [alter table history_text drop column id]
6963:20180306:160307.555 database upgrade failed
Any solution???
thx in advance
this is the logs :
Any solution???
thx in advance
