Some help to monitor 1000+ nodes
  • bcgsc_allan
    • Jan 2018
    Really happy with Zabbix 3.4 currently. However, I am looking for a way to monitor 1000+ nodes easily without manually installing the agent 1000+ times and then adding every host on the front-end one-by one.
    Any suggestions?
    Thanks in advance.
  • UncleSam
    • Aug 2013
    And what problems? Automate these actions.
    If you have 1000+ nodes, уou should already have a system that allows you to simultaneously deploy software to them. If you do not have such a system - you already have problems.
    Adding 1000+ single-type hosts using the API or import via XML also does not a problem.
    • tcilmo
      • Nov 2016
      • 122
      Any suggestions?
      Thanks in advance.
      Use a configuration management tool such as Puppet to deploy the agent and take advantage of Zabbix auto registration piece.
      Perforce Puppet is the leading modern infrastructure ops platform for automation, configuration management, DevSecOps, compliance, CI/CD, patching & more.
