asking for help about alert log monitoring of two oracle instance on same server
  • a4221722
    • Mar 2018
    hi there,
    I just encountered a problem today. I had added two oracle instances on the same machine for monitoring. And they have their own alert log respectively. Corresponding items of type 'log' and triggers were added for them. The key of the item is "log[{#ALERTLOG},"ORA-|Checkpoint not complete|Can not allocate log|fail|halt|abort|panic",,,skip,]".
    I finally found that only one of these two triggers remained valid as when there was an ORA error rise in the alert log of the second instance, the second trigger was not triggered. And the query
    "select lastlogsize from items where hostid=xxx and name='alert log'"
    in zabbix database returns zero.
    I doubted that the following code is relative with the problem:
    ./src/zabbix_server/operations.c lines: 41-90
    switch (event->object)
    result = DBselectN(sql, 1);
    I appreciate any help and applies.
    Thanks!
