Hi everybody,
I just started using Zabbix and ran into some problems. I have an agent running on a RasperryPi and a Zabbix Server within the same network. To get the CPU temperature to the zabbix server I use a script that is called by zabbix agent. I receive this data in the server frontend without problems. But when using the Linux OS Template on the same host I receive no data at all. Further more i get a red ZBX button in the host configuration on the frontend:
My zabbix-agentd.conf looks as follows (removed all comments):
Do I need another agent to perform the passive requests? Or am I missing something in the configuration?
Thanks for your help!
"Received empty response from Zabbix Agent at [ip]. Assuming that agent dropped connection because of access permissions."
PidFile=/var/run/zabbix/zabbix_agentd.pid LogFile=/var/log/zabbix-agent/zabbix_agentd.log LogFileSize=1 DebugLevel=3 Server=<IPv6>, zabbix.example.com ListenIP=0.0.0.0 ServerActive=<IPv6>, zabbix.example.com Hostname=RaspberryPi UserParameter=raspberrypi.sh[*],/usr/local/share/zabbix/externalscripts/raspberrypi.sh $1
