Wildcards in triggers & actions?
  • Vanyuan
    • Feb 2007
    • 28
    Halo All,
    Can wildcards be used? Is it possible to create a single action to notify me when any of my servers go down? I have fping working.
    V
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    For actions, you certainly can, however, triggers require a trigger for each item that you wish to alarm on, so you will need to create a trigger for each host that you are pinging, though this is childs play if you are using templates.
    Unofficial Zabbix Developer
