Using the change function in trigger - V1.1.4
  • entorno
    • 21
    Hi guys,
    We're trying to create the following trigger, which uses the change functinon, but it says our syntax is correct. We can not see where the mistake is... could any help please?
    ({Linux_Simple:http,2082.change}=-1)&({Linux_Simple:http,2082.prev(0)}#1)
    We want to see if the difference between the previous and current values = -1, and also that the previous value != 1.... if so, trigger.
    Many thanks.
    Entorno Digital
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    I think what you want is something more like;
    ({Linux_Simple:http,2082.change(0)}=-1)&({Linux_Simple:http,2082.prev(0)}#1)
    Unofficial Zabbix Developer
