Tick Item / No Data Trigger
  • scott
    • May 2006
    • 17
    Zabbix 1.1.4
    Freebsd 4.7, 4.8, 5.4
    I am having trouble getting data returned for "tick" item. I have followed the instructions on the Trigger page:
    Use of function nodata():
    {zabbix.zabbix.com:tick.nodata(180)}=1
    ‘tick’ must have type ‘ZABBIX trapper’’. In order to make this trigger work, item ‘tick’ must be defined. The host should periodically send data for this parameter using zabbix_sender. If no data is received within 180 seconds, the trigger value becomes TRUE.
    I have not found any other mention of said Item. Any assistance is appreciated.
  • scott
    • May 2006
    • 17
    still having trouble
    Still having troubles getting TICK item to function. Here is my config:
    Description: Tick
    Type: Zabbix Trapper
    key: tick
    Type of Information: Character (have tried all types)
    Show Value: As Is
    Item Appears Active but does not produce any data. I do not see any reference to this item in the documention
    http://www.zabbix.com/manual/v1.1/config_items.php
    I have been unsuccessful doing a man -- tick on both a FreeBSD and Linux box. Also not finding any help on Google.
    Any help is greatly appreciated. If a zabbix agent goes down, no data comes in and triggers do not function, alerts do not go out. This is a very bad thing.
    • scott
      • May 2006
      • 17
      work around
      Well since I am a Tick NOOOOB, i did a workaround.
      {zabbix.zabbix.com:version[zabbix_agent].nodata(240)}=1
      Tested and works.
      • stkr
        • Feb 2007
        • 18
        how did you defined "version[zabbix_agent]" ? Is this a UserParameter oder an Item? Could you explain this?
        Thanks a lot
        stkr
        • krusty
          • Oct 2005
          • 222
          watch the items of host "Host.Unix". There you can find this item.
          • Kian
            • Aug 2020
            Hi Gys
            when i create this condition suddenly all of my Host even those which have Data on not fired trigger
            this is my condition for power supply of Switch that havent Data on it
            {Cisco Total SNMP-V3:sensor.psu.status[ciscoEnvMonSupplyState.{#SNMPINDEX}].nodata(60)}=1
            is it wrong ? Any help is greatly appreciated
