Remote Command doesn't like spaces
  • rbarrero
    • Mar 2007
    • 21
    Hi;
    After all this testing, i realize I CAN run remote commands... but not if the commands contain spaces.
    sudo /etc/init.d/httpd start
    I wrote a small script called "httpd-start" that contains the above command and it works.
    Does anyone else have this problem?
    Thanks!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Any or prefix/trailing spaces?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • rbarrero
      • Mar 2007
      • 21
      This is the exact command:
      No prefixes or trailing characters. I am able to execute the command above by writing a dump wrapper script that contains no spaces or strange characters.
      Permissions are correct on the file (httpd). I can run the init scripts as remote command _without_ the "start" argument, and prints Usage parameters. With the start argument it fails.
