Help starting to use zabbix
  • sytker
    • Mar 2007
    I´ve installed zabbix server and agents on some of our servers (1.1.6ver)
    So here what I´m doing:
    1. I´ve created a template called basico and have put on Templates Group.
    2. I´ve created two itens on Basico:
    Description Key Type
    FTP ftp_perf Simple Check
    HTTP http_perf Simple Check
    But I couldnt add a trigger:
    Name: FTP server down on {HOSTNAME}
    Expression: {Basico:net.tcp.service[ftp].last(0)}=0
    No dependences defined
    I´m getting this error:
    [ERROR:Cannot add trigger]
    No such host (Basico) or monitored parameter (net.tcp.service[ftp])
    What am I missing?
    Thanks for any help.
  • mary nancy
    • Jul 2005
    • 125
    Plwease configure the parameter "net.tcp.service[ftp]" under Configuration->item for Basico template then add the trigger
