how to use this function "now"
  • scotti
    • Dec 2005
    • 32
    Hi, folks;
    how can I use this functions when I'm setting up a trigger?
    I have try the examples listed here
    http://www.zabbix.com/manual/v1.1/config_triggers.php
    I want an expression to return the seconds since it's last modified.I have tried these, but none of them worked.
    (now-{tpl:vfs.file.time[/somefile,modify].last(0)})<900
    {tpl:vfs.file.time[/somefile,modify].last(0)-now}<900
  • stkr
    • Feb 2007
    • 18
    That is what I want, too. Can anyone help?
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Use the 'now' like this: {tpl:vfs.file.time[/somefile,modify].last(0)-tpl:vfs.file.time[/somefile,modify].now(0)}<900
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • scotti
        • Dec 2005
        • 32
        I've tried, but received the following warning:
        No such host (tpl) or monitored parameter (vfs.file.time[/somefile,modify].now(0)-tpl:vfs.file.time[/somefile,modify])
        the tpl is a template not a real host, and I'm using zabbix-1.1.1
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          It should be {tpl:vfs.file.time[/somefile,modify].last(0)}-{tpl:vfs.file.time[/somefile,modify].now(0)}<900
          Alexei Vladishev
          My Twitter
          • scotti
            • Dec 2005
            • 32
            it seems a bug in 1.1.1, I'll try other versions, thanks, Alexei!
            • sbadger
              • Dec 2005
              • 81
              Just checking, but do you have a item for vfs.file.time[/somefile,modify] in the tmp template?
              • James Wells
                • Jun 2005
                • 664
                Greetings,
                I recommend going to 1.1.6. What you are describing is a known bug in all 1.1 versions prior to 1.1.6.
                Unofficial Zabbix Developer
                • scotti
                  • Dec 2005
                  • 32
                  Originally posted by James Wells
                  Greetings,
                  So good! Many thanks!
