Hello all,
I'm trying to install zabbix in a couple of closed networks to gather statistics. But there is an architecture problem. The master server can't run on these closed networks. Is it possible for the agents to gather the data, keep the data payload locally and then export them to the master server with another semi-manual mechanism? Is it also possible for the master server to receive this data in a semi-manual way? (Like introducing the data directly to the database or send the payload data somewhere where it will pick up and process)
Thanks for the help.
Regards
Regards
in your master server and then use that DB layout on the disconnected sites.
