Uninstall
  • jonmor
    • Sep 2006
    Uninstall
    How do I Uninstall Zabbix to install it to install it in a different directory?
  • mhammett
    • Jan 2007
    *bump*
    I am interested in this too.
    • mhammett
      • Jan 2007
      Apparently no one wants us to leave.
      • nelsonab
        • Sep 2006
        • 1233
        There is no "procedure" per se. You basically reverse the install process.
        stop zabbix
        remove binaries (usualy found in /usr/local/sbin)
        remove the php files (this depends on your distribution)
        run the mysql client
        - drop database zabbix; (unless you specified a different name)
        - quit
        delete the zabbix config directory
        - rm -rf /etc/zabbix
        delete the init script if you set one up.
        - rm /etc/init.d/zabbix_* (unless you used a different name)
        Welcome to a world without Zabbix
        RHCE, author of zbxapi
