Apply triggers to a template
  • mg3
    • Mar 2007
    • 9
    I would like to know if it's possible to apply triggers to a template. For example I have a template Host.SNMP and I create triggers to check diskspace, cpu, server is reachable,...
    If I write a trigger like this:
    {Host.SNMP:icmppingsec.last(2)} = 0.0
    Would it be applied to each host who uses the template? So I don't have to rewrite this trigger for each host with its own hostname filled in.
    Greetz,
    Jo
  • voyager
    • Mar 2007
    Yes, it is- all hosts linked to that template will use the trigger, the same occurs while updating the trigger.
