Trigger Blinking
  • welkin
    • Mar 2007
    • 132
    Trigger Blinking
    If got 2 Triggers set up:
    1: Trigger when agent.ping delivers no data for more than 60 seconds
    and
    2: Trigger when the last icmpping value is not equal to 1
    Both are working as expected, but in the web frontend the icmpping trigger is always blinking (changing from white to green) what does that mean? And is it possible to trigger only when the last 10 values for icmpping are not equal to 1?
    thanks in advance,
    welkin
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    {host:agent.ping.max(#10)}=0 - All the last 10 values are equal to 0.
    The blinking starts working when a trigger changes its status. I believe it blinks faster within first 15 minutes, then slower within 30 minutes, then it becomes steady green or red.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • welkin
      • Mar 2007
      • 132
      Thanks for the quick answer.
      I got another question:
      How exactly does icmppingsec work? Does it just one ping per PingerFrequency, or does it e.g. 5 Pings per PingerFrequency and than gives out the avarage response time? And if it does just one Ping per PingerFfrequency what parameters are passed to fping? It would be great to know so that i can write a script which does 5 Pings instead of just one and then passes the avarage of these to zabbix.
      thank in advance,
      welkin
