Zabbix 1.1.6 server running on Fedora Core3 monitoring w2k servers running agents.
The latest values does not update. I have setup agent.ping to all servers. I receive no data. When I check latest values last check is many hours past. Update intervals are set to 60secs for item agent.ping. Graphs display no data.
If I edit and save the agent.ping item, i see min:1 max:1 last:1 in graphs. This does not remain. Seems it only check after I have open then saved the item.
ran fport and that checked out. Ping to zabbix server and server to host is ok.
