snmp AND agent?
  • robbertwethmar
    • Mar 2007
    snmp AND agent?
    is it possible to use snmp AND the agent on the same host? I want to monitor windows machines. If i start the snmp service i have some info the zabbix agent doesn't have...
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Sure, it is possible and perfectly ok.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • robbertwethmar
      • Mar 2007
      but what port nr do i use in the host definition then? 161 for snmp or 10050 for the agent???
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Please 10050 as it is. SNMP port number is configured on item level in order to allow monitoring of several SNMP agent running on the same box.
        Alexei Vladishev
        My Twitter
