Hi Guys,
Hope someone can help. I'm stumped.
I am seeing the following error in the zabbix-server.log:
Failed to connect to database: Error: Client does not support authentication protocol requested by server; consider upgrading MySQL client
Checking for Zabbix Version:
server-specialists:~# zabbix_server -v
ZABBIX Server (daemon) v1.1 (2 Juna 2006)
Compilation time: Jun 7 2006 20:08:56
I'm running MySQL 5.0.32
Can anyone point me in the correct direction in resolving this? Thank you in advance.
Regards,
John Z.
Regards,
John Z.
BI wants the shorter version. (I discovered this using Webmin on my MaxDB instance -there is a checkbox that is essentially "use the old password method" -which I think is 64 and not 128 in length).
