Help on monitoring SNMP variables type IpAddress
  • gabin
    • Mar 2007
    I'm using zabbix to monitor a few Cisco routers. On a couple of them I want to check routes stability so I want to monitor SNMP variable
    .iso.org.dod.internet.mgmt.mib-2.ip.ipRoutingTable.ipRouteEntry.ipRouteNextHop
    I have trouble configuring a trigger for when the IpAddress in "ipRouteNextHop" changes.
    Please help
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    For something like that, I would suggest trying something like the following trigger;
    {ROUTER:.iso.org.dod.internet.mgmt.mib-2.ip.ipRoutingTable.ipRouteEntry.ipRouteNextHop.diff(0)}<0
    Another option would be to translate the MIB to it's numeric syntax to try to shorten it a bit.
    Unofficial Zabbix Developer
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Note that the key can be any unique string for SNMP item. It makes little sense to use long numeric or string OIDs for the key.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • gabin
        • Mar 2007
        I configured the trigger and now i get the following messages in the server log
        2145:20070321:115131 Parameter [1.3.6.1.2.1.4.21.1.7.10.201.0.0] is not supported by agent on host [router_1.19] Old status [0]
        2145:20070321:115131 Cannot store SNMP string value (ASN_IPADDRESS) in item having numeric type
        i tried to config the type as integer,float,text and it didn't work
        i also checked the snmp variable and it works:
        [root@netmon root]# snmpget -Os -c *** -v 2c 10.254.1.19 1.3.6.1.2.1.4.21.1.7.10.201.0.0
        ipRouteNextHop.10.201.0.0 = IpAddress: 192.168.250.2
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Please try to configure this item as a string.
          Alexei Vladishev
          My Twitter
          • gabin
            • Mar 2007
            after setting type "char" and setting trigger
            {ROUTER:.iso.org.dod.internet.mgmt.mib-2.ip.ipRoutingTable.ipRouteEntry.ipRouteNextHop.di ff(0)}#0
            the trigger activates when route changes.
            Thank you
            Gabriel
