run housekeeper
  • sid
    • Jul 2006
    • 44
    run housekeeper
    For some reason, the data in my trends table has disappeared. (I checked retention periods) So when I try to look at a graph for a period of more than 24 hours, I cannot look at any data.
    However, the data is still in my history table. So I can view the data but in smaller time frames.
    Does anyone know if there is a way to update the trends table using data from the history table?
    Is this a housekeeper issue?
    Thanks for the help.
  • aspeer
    • Feb 2007
    same issue
    I am experiencing the same sort of issue with my trend data missing but historical data being present. I also need a way to make the housekeeper run and move the historical into the trend table.
    Any help would be appreciated,
    Thanks.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Both history and trends are updated online as soon as ZABBIX receives a new value! Not need for any batch processing.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • aspeer
        • Feb 2007
        What is the sql that it runs to update this table? We need to manually populate it since we had a data loss in trends but still have the historical. We just need to know how zabbix averages the data in order to maunally recreate it based off the historical data.
        Thanks.
