Running triggers on specific time
  • predatorz
    • Mar 2007
    • 109
    Is it possible to make triggers for simple check to run only on specific timing ?
    e.g. i only want the ping trigger to run from Monday to Saturday, Monday to friday(24hrs), sat(8am - 7pm)..
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Use time-related functions supported by trigger expressions.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • predatorz
      • Mar 2007
      • 109
      Can i use the time related function for the items to run only at specific timing.
      E.g. Template:icmpping where should i put the time function?
      is this the correct way? {Template:icmpping in 1-5, 0800:1800
      • predatorz
        • Mar 2007
        • 109
        How should i write to only run items for checking at only specific time?
        Is it doable?
        If i put the statement as icmpping, in 1-6, 0800-1800, will give an error saying that not supported....(For item Ping).
        Please help me.....
