Went looking for ping in simple checks, and there isn't one pre-configured. How can you have a simple checks category without a ping check?
It really should be added.
I'd like to monitor that specific subnets are up by pinging a router, or a device on that subnet.
Anyone have suggestions on how to add the proper item & trigger. I'd also like it to be delayed, ie, if its negative for 5 or 10 minutes. I searched the forum, and scanned the wiki but found no tutorial that helped me enough...
It really should be added.I'd like to monitor that specific subnets are up by pinging a router, or a device on that subnet.
