same trigger for thiusand items
  • rileo8
    • Feb 2007
    • 27
    i have thousands of items on which i want to add the trigger.
    There is a way to add only one trigger?
    items key are like dpc1status,dpc2status,dpc1000status etc...
    Thanks,
    Riccardo
  • steftheo
    • Feb 2007
    • 11
    templates!!!
    Hi.
    Do you have this items belong to a template???
    if you have added the items on a template then the one trigger will effect all the items on that template. If you don't have template or you have different templates for a number of items then you have to make triggers for all the templates or items you have created.
    As far as I know this is the way it works and this is the way I work on my network.
